PCV valve and oil filter q's
My 96 civic has almost 100k miles and I have personally never changed the PCV valve so I'm going to do it on the next oil change. I read somewhere that the OEM ones are spring loaded and the aftermarket ones are not, but the one I got from AAP is spring loaded so I will use it, I think. My question is: is the valve supposed to be stricly one way? Beacuse if I try and blow air through one end I am able to, but not at a high rate. So is this thing defective, or normal?
Also, if i take the Oil filter out with out draining the oil from the oil pan, I will only lose the oil that is in the filter correct? No oil will drain from the fitting where the filter screws into?
RE: PCV valve and oil filter q's
if htere isnt alot of sludge build up in ur engine then i wouldn't worry about changing pcv valve. you will only lose oil that is in filter. and y would u want to change filter and not oil????
Well, I took my car into Honda a couple months ago to get the exhuast manifold replaced under waranty beacuse it was cracked, and they told me that they had to perform a service on it (oil chagefilter, spark plugs, wires, cap, rotor) So they did all that, and I went to change my oil the other day and I usually drain it, then take the filter off, so it finishes draining, and I go to take the filter off, and the damn tech had to have used a wrench to tighten it because it's on there gorilla tight! And I didn't have a filter wrench for that size filter because I always just hand tighten my filters, so I had no choice but to leave it on there and go buy a filter wrench after I added the fresh oil....
For the PCV valve, your supposed to shake it, and if you can hear a rattle, then your good, if not,replace it, but if you have never replaced it, you really should. I have never replaced mine but from doing some research, I plan to do mine my next oil change because I have some of the signs it needs to be replaced. For the oil filter, I'm pretty sure your going to get a good amount of oil draining out...
yeah a good PCV valve should make kinda like a rattling sound when shook. when installed, u'll hear that same kinda rattling when the car is on.
as for the oil filter, u can take it out without all the oil draining from it.there will be a fair amount of oil coming from inside the filter tho. just take the old filter off, put the new one on, let the car run for a minute, shut it off, and check the dip stick. may be a tad low so just add untill at correct level.
ORIGINAL: mill$civic
PurePlayaa420
04-27-2011 08:21 AM
oilltd
06-10-2008 04:06 PM
oilltd
South West
06-10-2008 03:07 PM
