panel removal
Old 10-14-2006 | 06:51 PM
stephelton's Avatar
Default panel removal
So I'm wanting to install a new head unit in my 01 LX but I'm having trouble with the clips. I found a PDF that helps me locate them:
http://www.tss-radio.com/images/HO-52-01.pdf
but I'm not exactly sure how to disengage them. I have a small hook shaped tool but I'm not sure what to do. If anyone who has removed the control/cigarette lighter panel on the same gen civic can describe them, or better yet, provide a picture, I would be very grateful.
Thanks...
~Stephen
Old 10-17-2006 | 08:02 PM
stephelton's Avatar
Default RE: panel removal
ttt
come on, surely someone has removed this panel before...
Old 10-24-2006 | 02:41 PM
stephelton's Avatar
ttt
Old 10-28-2006 | 04:53 PM
stephelton's Avatar
ttt
i'll give it another shot... any help at all would be appreciated...
Old 10-28-2006 | 05:03 PM
TheMoogly's Avatar
What does ttt mean?
http://www.ledautomotive.com/HowToGu...shLEDHowTo.asp
This is the DIY to convert your climate control to blue leds but it mainly tells you how to take off your cluster! Good luck
Old 10-28-2006 | 05:24 PM
civicexracer's Avatar
ttt=to the top
Old 10-31-2006 | 12:27 AM
stephelton's Avatar
thanks that is close enough to what i'm looking for! much appreciated!
Old 11-07-2006 | 12:47 AM
stephelton's Avatar
So I finally got around to installing my radio and I thought I'd explain a bit...
First I removed the cigarette outlet panel thing. What I did was take a couple credit cards to slip behind the top corners which allowed me to get a grip and pull it out. (I suppose the proper thing to do is to use a tool to unclip the retainers, but this worked for me without damaging anything.)
Next I removed a couple screws underneath the radio. They were kind of hard to reach. Used an 8mm wrench to do the job - they stripped very quickly with a phillips screwdriver.
Then I used a credit card to slip behind one of the corners of the radio panel so I could grip it. There are 9(?) retaining clips holding this one on. I went around in a circle and gently pulled until each was lose, and it came right out after that.
Hope that helps others understand the process. I found lots of misleading info out there.
~Stephen
ptw711
02-23-2006 11:51 PM
jwa1r2t3
01-23-2006 05:36 PM
PredatorCoder
08-15-2005 06:43 PM
vmf
07-13-2005 10:12 PM
me2
12-11-2004 09:17 AM
