Overheating Issue.
Old 07-19-2010, 11:17 AM
K.G.'s Avatar
Another update;
I made a 10 second video and uploaded it to Youtube today with Car running 30 seconds after I turned it on.
Also here are some pictures:
Old 07-19-2010, 11:20 AM
and have you changed anything yet .....
Old 07-19-2010, 11:27 AM
K.G.'s Avatar
I also took a bit of coolant/water from the Radiator Overflow and put into a Can and took a picture of it.
The Brown specs are coffee grounds, didn't clean the can out before I poured the coolant into it
Not sure if that looks like the milky brown color as mentioned.
Once again thx all.
Tryin to determin of its clogged, tstat - or h-gasket.
Right now only jack I got is the change tire jack, and I really dont wanna go under the car to do a flush with that jack so waiting for a bigger one.
Old 07-19-2010, 12:13 PM
You do not need to jack the car up.
Reach underneath and open the radiator drain, drain into a CLEAN container so you can potentially re-use it. Your coolant looks quite clean. If it's more than a couple years old though you should replace it with new anyway.
Remove thermostat. It's on the engine end of the LOWER radiator hose, not the upper like most American cars. Remove the two bolts and split the thermostat housing open.
Use a water hose put water into the radiator and make sure it drains freely out of the lower hose (still disconnected). If it does not, remove radiator and probably replace it. The radiator is removed from the top, again no need to jack car up.
Install new thermostat. The end with the copper sensing bulb goes TOWARD the engine, and the hole in the flange with the little pin in it goes at the top.
Refill and bleed system, check for leaks.
Test drive.
Old 07-19-2010, 01:31 PM
honda_farmboy's Avatar
Banned
oh **** that doesn't look good in the video. good luck fixing that ****ing thing lol
Old 07-19-2010, 02:18 PM
K.G.'s Avatar
Just an update, as I never see resolutions on a few topic's.
White smoke started coming out of the exhaust for about 2 minutes and the car stalled multiple times. (Shook bad then stalled out) I strugled to keep the car running.
Took it in to get a diagnose and been told it's unfortunately the Head Gasket.
The car was stalling due to coolant getting into the cylinders. Exhaust and Bubbles apparently were the exhaust coming back through.
I was quoted by a repair shop $700 - $1000 Canadian to Repair/Fix my 88 Honda Civic!!!!
Thank you cvcrcr99, 94civichatchback & mk378 for your fast, helpful and speedy replies. Helped me narrow it down.
Old 07-19-2010, 02:22 PM
Head gasket is potentially a DIY job. It's a $25.00 part but a bunch of labor. The problem with paying someone to do it is that if your engine is warped or cracked it will still leak and you've just wasted the money. There's no way to tell for sure without changing the gasket and trying it.
Old 07-22-2010, 09:45 AM
K.G.'s Avatar
1 More quick question. Does these Estimates sound about right? (Canadian $)
6 Hours Labour @ $95/hr: $570.00
Parts for Head-Gasket: $450
Machine Shop: $250 (Cylinders warped)
= $1270.00
Timing Belt: $80.00
+ 12% HST (tax)
= $1512.00 Repair Bill
- Local shop
Thx again all.
mudhenFUF
01-16-2023 08:43 PM
ccarlozz
07-12-2009 08:41 AM
paintman17
09-19-2006 09:14 PM
trebor_2005
05-19-2006 01:40 AM
mahmi
12
01-13-2006 08:03 PM
Quick Reply: Overheating Issue.
