Over Heating and cant figure it out starting to make me mad
Old 10-21-2011 | 11:11 AM
ZeMo's Avatar
Default Over Heating and cant figure it out starting to make me mad
Hi i have a 94 civic lx auto. Here is my problem my car started overheating so i thought it was my t-stat so i changed it and still over heating i noticed when im idling the temp gauge goes up and when i start driving it goes down. Second thing i noticed is the resivour is overflowing it looks like it the coolant isnt circulating. I was thinking there might be a block somewhere stopping the circulation. Any suggestions would be appreciated
Thanks
Old 10-21-2011 | 12:05 PM
Overheating primarily when sitting still is often because the radiator fan doesn't work. Unplug the fan switch on the thermostat housing and jump it. The fan should now start immediately when you turn the key on. If it doesn't, check the fuse, motor, and relay. Test drive with fan running all the time.
Old 10-24-2011 | 12:17 PM
D16Y8Civic93's Avatar
take your thermostat out and see if that helps. only thing its used for is to heat up your car anyways
Old 10-25-2011 | 10:23 PM
Mcgarvie's Avatar
Most likely headgasket... almost guarantee it
Brian1997
07-25-2014 05:04 AM
edyo74
09-24-2006 10:37 AM
tonguetwiztid
07-19-2006 10:13 PM
solewheelin
07-07-2006 07:18 AM
Quick Reply: Over Heating and cant figure it out starting to make me mad
