opinions on best way to replace fuel lines on an EK
all right so I've done a bit of online hunting and there isn't much out there for fuel lines. I found the OEM set for about $240, nylon flexible tubing for cheap, and Russell aluminum tubing for $80.
The way I see it I have three easy options:
1: buy OEM lines and some nylon hose, cut the oem lines where they thread through the body at the back of the engine compartment and use nylon to thread through.
2: buy nylon hose and just run straight nylon along the underbody.
3: buy aluminum tubing for the run under the passenger compartment and nylon to link it at both ends.
Honestly I've been leaning towards nylon line all the way. I can add extra mounts (91598-S04-013) to keep it from sagging. Can anyone with experience think of a reason to go more expensive?
thanks for reading~
thanks for reading~
Scott53092
09-07-2009 08:38 PM
jgutka
12-03-2007 09:30 PM
jgutka
06-09-2007 01:24 PM
jgutka
05-01-2007 08:25 AM
