Oil leak?
Oil leak?
I have a 94 Civic LX sedan with 102,000 miles on it. When i last changed my oil, i found that i did not drain enough oil. THen i checked the oil level again in about a two or three weeks and found that the engine was 1/4 quart low. Im pretty sure this kind of oil loss is not normal. I don't see any visible oil leaks and i didn't really notice a blue exhaust. Can anyone tell me how i can find the source of this problem?
RE: Oil leak?
ORIGINAL: HondaCivica
If your using syntec oil that could be the problem too.
Now back to the origional question. Even if you don't see any blue smoke, you can be burning oil. very little oil, but still some nontheless. If the valve stem seals are the ones that are letting oil through, you will see very little puff of smoke after the car had been sitting for about a day or so. This puff of smoke will only be seeing when you initially turn on the car then no more. If the oil is going in through the piston rings, you will see the puff of smoke every time you floor it. The only time you see a lot of smoke while the engine is idling is when there is something seriously wrong with it, like a really burnt up piston ring.
RE: Oil leak?
I was thinking rings as well, but i can't see the smoke when i floor it so ill have to check. Also should the smoke be white or blue. Im running regular oil. And i have added oil and checked later on and found that there was less oil.
theRDRman
11-28-2011 04:18 PM
oilltd
06-10-2008 04:06 PM
oilltd
South West
06-10-2008 03:07 PM
