OBD2 to OBD1 conversion.
#21
RE: OBD2 to OBD1 conversion.
ORIGINAL: defjamon22z
wut does dizzzy means? distributor? i dont know if my car had a d18y8 engine before but my car is a 96 LX so im assuming yeah? so my hardness is a d18y8 and my distributor is a d18y8 part obd2 so i gotta change it or... change the plug and match the color?
#22
The distributor will be different because of the crank sensor , get OBD1 distributor , what harness are you going to use ?
#23
wow one guy says i DONT need a dizzy and wes94si says i need to get a obd1 distributor. which is it guys? i got a 96 LX 4 door automatic with a d16z6 engine. the dizzy is obd2 but it bolt on with only 1 screw. the hardness is the same. the ecu isnt p28 it's sumthing else. im going to the junkyard tmw after work hopefully someone respond quickly so i know what to grab or i might overspend on things i dont need
#24
need to convert this obd 1 dizzy to obd 2
I have a 96 ek hatch dx. I recently swapped the head for a z6. My problem is my car is running with the putts. The dizzy I have on now is from a obd 2 civic but it doesnt bolt up so its just on there at a weird angel, so i figure the timing is off. So now im looking for a z6 dizzy, but i dont know how to re pin or what to do to mke it work once i get it.
#25
Please start a new thread. This one is 4 years old.
change, conversion, conversion, convert, converting, d16, distributor, dizzy, ecu, ek, harness, honda, jumper, obd1, obd2
