o2 sensor and speedometer and odo not working
Old 02-07-2008 | 07:17 AM
classic97's Avatar
Default o2 sensor and speedometer and odo not working
I have a 97 civic manual with 237,000 km. Engine light came on with codes for Both o2 sensors. At the same time the dash dimmed and the speedo and odometer stopped working. Any ideas? No code for the speed sensor. Thks
Old 02-07-2008 | 06:25 PM
Default RE: o2 sensor and speedometer and odo not working
Is fuse 15 in the under-dash fuse/relay box blown? If so, you probably have a wire harness that has been damaged and a wire(s) in it is shorting on a bracket on the intake manifold between the firewall and engine.
See here:
http://autorepair.about.com/library/faqs/bl021d.htm
Old 02-09-2008 | 03:43 AM
classic97's Avatar
Thanks....will have a look today..cheers
theeoriginal23
07-26-2010 06:39 PM
gfield13
02-19-2008 11:02 AM
pjperez64
08-06-2007 09:03 AM
rdas45
03-02-2007 08:03 AM
chrisroug
10-02-2006 11:36 AM
Quick Reply: o2 sensor and speedometer and odo not working
