Not Sure a little lost
Old 11-25-2007 | 02:15 PM
civicraider's Avatar
Default Not Sure a little lost
Ok so I have a 98 civic EX 5spd and when warm sometimes the IDLE will drop to around 500 or less has been known to actually stall once in a blue moon. I did search and some have said the IACV and some have said the O2 sensor. I dont want to spend a bunch of money but i want to fix the problem. I have a Pioneer Indash Navigation that has a volt meter and when this idle problem occurs then the voltage will drop ot around 11.4 ish and it will run normally at 14.4 so what can it be should I start with the O2 sensors??
Old 11-25-2007 | 02:18 PM
Mugan's Avatar
Default RE: Not Sure a little lost
Yes start with the O2 then go from there.
Old 11-25-2007 | 02:20 PM
Thanks thats what I thought and would it be the upstream or downstream sensor??
Old 11-25-2007 | 02:56 PM
Mugan's Avatar
I'm thinking its down stream go with the cheapest. put it in if that does not work see about returning it and try the other. Also look at the map senser.
Old 11-25-2007 | 03:16 PM
mybrokenblinker's Avatar
the second one is for monitoring purposes ONLY. It will not change how the car acts. Changing the secondary one will do nothing.
Old 11-25-2007 | 03:22 PM
I completely agree with Mugan. Return parts if they don't fix the problem; however, first ask the store about their return policy to avoid potential problems.
I would also suggest that you try cleaning the IACV with carburetor cleaner before replacing the O2 sensor.
Given that low voltage may precede your low idle problem, you might eventually also want to consider that your alternator may be on the way out.
Finally, does the Check Engine Light turn ON when you have the idle problem?
Old 11-26-2007 | 03:13 PM
No CEL and the ALT is new!!! so it better not be on its way out.... but there is always the chance. I will check the IACV and then the O2 Sensor
Old 11-26-2007 | 04:14 PM
mxs's Avatar
mxs
You need to adjust your idle and get any air bubbles out of your coolant system.
Old 11-26-2007 | 07:47 PM
Thanks will do tomoro and then let ya know what happens
blackmassacrer
01-31-2008 10:07 PM
mike1987
12-09-2005 09:37 AM
chriskatana
08-10-2005 10:15 AM
bradwitt
07-01-2005 04:23 AM
hisokano1
04-03-2005 08:30 PM
Quick Reply: Not Sure a little lost
