Noisy valve train
Noisy valve train
So i'm about to buy an 88 hatchtback, and the valve train seems to be awfully "Clicky". ITs not a loud click and when you rev the motor up it doesnt get louder and louder, it kind of gets drowned out. is it normal for that year engine to jus tbe sort of noisy? maybe the valves just need adjusting?
RE: Noisy valve train
You should take the valve cover off, and see if the tappets are loose (if that model has tappets) and ifnot, grab some valve springs and see how much sideways movement they have. If they have lots, it's in need of a new set of valves and valve guides (which also means new or recut valve seats). Of course, if the tappets (if they have them) are just loose, than it's just a case of adjustment isn't it.
Hope this helps
Hope this helps
