noise in dash passenger side
I have a 2001 Civic. Recently, once I release the parking brake a whirring noise starts from under the passenger side dash. Sometimes it stops after a while sometimes not. It is relatively constant, doesn't change regardless of whether my AC or Fan are on/off. Engine speed doesn't matter-the noise starts when the car is in park. It sounds a bit like a wind up toy winding down. Anybody have any ideas? I just had an extensive service done a month ago at about 95,000 Km . Thanks for any help.
RE: noise in dash passenger side
If its in motion it could be something as dumb as brake wear indicators. Might not have anything to do with your gearbox really or the fact that its in neutral. If you had extensive service then its probably not the brakes, but have you hit anything hard recently?
Haven't hit anything hard, no. I popped the glovecompartment off and and the sound is coming from in the dash, not in the engine/transmission. The general area where it seems to be originating has a lot of electrical components which I don't feel comfortable fooling around with.
Does the noise go away if you turn the headlights on? If so, run outside and see of both Daytime Running Lights are on. If one is out, it could be the DRL warning buzzer which indicates a fault in the circuit somewhere.
It is most likely the DRL Relay chattering because of bad solder joints in the DRL Module. The DRL Relay is behind the glove box, the DRL Control Module is LH of the Steering Column under the dash. Search General Tech Help for "Daytime Running Lights" OR search for the string "Full Meal Deal" where there is a more complete description.
civicrevolution
04-03-2011 04:27 PM
Jeremy102579
05-11-2009 08:12 PM
lunasin92x
12-18-2006 06:43 PM
Danny Boy
01-05-2005 07:03 AM
