No spark no fuel!!! Help?!
i recently picked up a 93 honda civic ex with the d16z6 the head on it was back so i replaced it with a head off 94 honda with a d16z6 i replaced the distributor the rotor the spark plug wires and plugs i also replaced the alternator ( it was locked up completely) none the less i got everything put back together where it goes and when i start it the motor cranks but im not getting any spark and it doesnt seem like its getting any fuel either.... all the fuses look good.... i have no idea where to even start... help?
If the BRAKE light doesn't stay on that means the ignition circuit is losing power when you turn the key all the way to III to crank. So that would make it crank but not start. Typically it is a bad ignition switch doing it.
gforce79
03-08-2007 07:02 PM
wongthao
11-17-2006 05:22 AM
civicexracer
11-09-2005 05:41 PM
