No spark, need help!
I have a 1996 Civic that I am at my witts end with. The car all of a suuden wouldn't start. I have checked all of the intermal components in the distributor (coil, ignitor) which check out fine. I have replaced the main relay and still no spark. I know someone out there has run into similar problems, any help would be GREAT! Thank you
RE: No spark, need help!
ORIGINAL: irate808
How do you know it checked out fine? Usually if there is no spark, the problem is the coil.
True, happened to me in my EG, doing 70 down the road and all of a sudden...nothing, my car just cut out
i got it towed to my work and had someone look at it, i tested the plugs and there was no spark at all..
the conclusion was an ICM-- not that expensive and reasonably easy to fit
Cousin_Joe
09-17-2008 06:44 PM
gforce79
03-08-2007 07:02 PM
jmb72105
02-09-2007 04:24 PM
mill$civic
11-18-2005 09:52 PM
