No Spark
Old 04-07-2007 | 08:34 AM
coolerman's Avatar
Default No Spark
just bought a 99 civic ex 5 speed the car ran great for a week but then it shut off. I checked the compression and that was good the timing belt was just replaced, the fuel pump is working i can smell fuel in the cylinder
NO Spark at the plug.
What ussually goes up in the distributor of a civic and are there any tricks in removing the distributor or replacing things like the control module or ignition coil HElp
Old 04-07-2007 | 12:52 PM
riceburner700's Avatar
Default RE: No Spark
check inside the distributor cap and look at the little points they may have some carrosion on them. i would try a tune up with a cap/rotor/some spark plug wires.
Old 04-07-2007 | 08:08 PM
AOL.COM's Avatar
i would say something in the distributor - coil, module , igniter - it may be cheaper & faster just to pop in a rebuilt one - if thats what it is -
another possibility may be a bad crank sensor - but i think a bad sensor would shut down both spark & fuel - but im not sure
outlawzz23
04-03-2008 08:56 AM
bulletman0_0
11-08-2004 11:17 PM
civic1.5uk
07-24-2004 03:15 PM
GWhiz
07-03-2004 11:00 AM
buzzro
06-10-2004 12:25 PM
Quick Reply: No Spark
