no power to obd2 port
my 01 civic lx has a cel and i have my own scanner but when i plug it in nothing happens. it should light right up and start reading, but i get nothing. is there a fuse or something that i dont know about? i thought it was connected directly to the ecu.
RE: no power to obd2 port
The manual for your code reader may show a diagram of the data link connector (DLC), where you can determine which terminal supplies battery power. With this information, you can use a multimeter or test light to directly test whether your car's DLC is receiving battery power. If so, the problem might be your code reader.
ORIGINAL: sto73
i think i may have lost the ground, anyone have any idea where to find that?
my code reader is good i just used it on my wifes car to check it. as for shared grounds my car is m/t and have no heated seats. i did have my center console out today installing a new shifter boot, i may have knocked something loose, but i dont think i did.
