No low end power when warm
Old 05-02-2011 | 03:29 PM
lone_wolf04's Avatar
Default No low end power when warm
1990 Honda Civic 1.6L 5 speed
About 4 days ago My car started running like crap when it reaches operating temp. Its Ideals like normal runs ok when its cold. When it gets warm there is like now low end power i have to rev it to about 3000 rpm to take off, cant climb hills, throttle response to POOR and its using about 3x as much gas as it usually does! HELP PLZ
Old 05-03-2011 | 09:11 AM
droopy128's Avatar
check your CAT..
Old 05-03-2011 | 09:20 AM
mundy5's Avatar
is the check engine light (CEL) on? It should come on if you have a problem with your CAT. The CEL is the first place I'd check. Auto parts stores will check it for you for free.
Old 05-03-2011 | 10:14 AM
This is probably a bad plug wire or distributor cap causing misfiring due to weak sparks. When the engine warms up the mixture leans out, making good sparks more critical.
ktorres1120
04-07-2008 04:54 PM
07SiMD
10-26-2007 07:13 AM
B!@ckBoYwiTaC!v!c
12-25-2006 07:38 PM
omgxitsxaxhb
02-12-2005 02:04 AM
dalifts
09-16-2004 01:09 AM
Quick Reply: No low end power when warm
