NO COLD ON MY CAR AIRCON
Old 04-16-2008 | 06:53 PM
maroon's Avatar
Default NO COLD ON MY CAR AIRCON
CAN ANYBODY TELL ME WHERE EXACTLY UNDER THE HOOD IS THE AIRCON COMPRESSOR IT BECOMING HOT THIS DAYS AND WHEN I TURN MY AIRCON ITS ONLY AIR W/OUT COLD.SO MAYBE I NEED TO PUT SOME FREON?I SAW ONE IN CAN,DO IT YOURSELF I THINK ,U THINK GUYS THATS OK TO USE?
Old 04-16-2008 | 07:23 PM
mundy5's Avatar
Default RE: NO COLD ON MY CAR AIRCON
it would help if we need what year and model.
you should be able to hear the compressor clutch engage when you turn on the a/c. if you do not hear a clicking sound, then you are correct in that the compressor is not engaging.
you also want to make sure that your car takes r-134a rather than the r12. you cannot buy r12 at the auto parts stores and you cannot mix the two. so make sure you look and see what kind of refrigerant your car uses. if it uses r-134a then you can go ahead and buy it in the can. it is more helpful to actually measure the amount of refrigerant by measuring the low side first before adding refrigerant.
if you choose to add the refrigerant and then the air is no longer cold after a week or less, then you have a major leak and you need to get that fixed first.
Old 04-16-2008 | 08:01 PM
Check for blown fuses. Do not add refrigerant unless you have proper gauges to measure freon pressure in the A/C system.
To properly troubleshoot the problem, search the forum for a downloadable service manual for your Civic. Low freon is only one of many potential causes for a non-functioning A/C system.
Old 04-17-2008 | 04:24 AM
burnindesirez02's Avatar
RonJ is right. You need a manifold gauge set to see the pressure on the high and low side of the system. if you do add freon yourself then make sure you add it to th e low side of the a/c system
maroon
07-05-2010 07:58 AM
general23cmp
12-20-2008 11:43 PM
frech88
05-21-2007 04:38 PM
wrinkledpants
12-03-2006 11:30 PM
kjreinha
03-31-2006 12:07 PM
