No blinkers...
Old 01-01-2008 | 02:29 PM
timmytim's Avatar
Default No blinkers...
Did a search and all I could find was about fast blinking. ---
I have NO blinkers.
NOTE: Blinkers worked find before engine replacement
Can anyone give me an idea where to start? (Fuses obviously, but all check out OKAY)
Old 01-01-2008 | 03:08 PM
Default RE: No blinkers...
Do your hazard lights also fail to work?
If fuses 10 and 34 are fine, then perform the tests detailed in the picture. The results should pinpoint the problem.
Old 01-01-2008 | 03:54 PM
timmytim's Avatar
Thanks again, Ron. I'm going to have a crack at it in the morning when there's some daylight. My hazards do not work.
Old 01-01-2008 | 04:52 PM
magic_mohawk's Avatar
Possibly could be a dead relay or you forgot to plug something back in.
Old 01-02-2008 | 06:11 AM
Pretty common for someone to pull the dash apart and forget to plug the hazard switch back in. The standard turn blinkers won't work in that case either; it's all the same circuit.
madmid3
08-02-2007 02:55 PM
DXhatch
04-30-2007 11:44 PM
smokingemcee
06-21-2006 09:07 AM
derekdunham
11-20-2005 10:30 AM
derekdunham
07-25-2005 10:39 AM
Quick Reply: No blinkers...
