New to honda's need help with firing order, Have checked everywhere cant get it right
Old 03-10-2011 | 01:00 PM
I've personally put a D15B7 distributor on 180 degrees out: it is possible if the parts are worn and/or you force it. I suggest starting from scratch and check all timing issues. Take the upper timing belt cover off and check the cam timing. After turning the engine by hand to TDC1, take the distributor cap off and confirm the rotor points at #1. Make sure the rotor screw is in place.
Old 03-12-2011 | 12:16 PM
beat2hell93civic's Avatar
Default Update
so, timing belt skipped I was able to slide it off by hand, At this point pretty sure I'm just going to do a mini me swap, as I can only guess that the valves arent going to be worth a ****. starting new thread As I cant figure out what is holding my head on as I removed all bolts.
milhouse
11-15-2008 12:31 PM
shvd95civic
09-07-2007 02:05 PM
greencivic
11-27-2006 08:53 AM
candicemarie
02-12-2006 02:57 PM
karim7
12-27-2005 08:20 AM
