Need Window Help
Need Window Help
when i roll up my passenger side window when it gets to the top before the glass tucks into the black weather stripping it gets stuck there, so it wouldn't roll all the way up. seems like the glass is going straight at the black weather stripping and stays on top of it, but not in front of it so that the glass continues going up.
but the window is still running on its track, its just when the glass gets to the top a black weatherstrip on the top is stopping the glass from closing, should i still remove the panel and check? what do i need to look for
but my window is still on track its just a weather stripping that is stopping the glass from moving up on the top. everything looks fine. could it be because of a new glass, because i had it replace because someone decided to break it.
This is assumes that the replacement glass was is the correct one.
This happened to me last week. You can watch the window go up you should be able to see in the black strip in the middle where the window should go. If it is on the outer side of it and stopping then the window has fallen off track but it will still go up and down this doesn't mean it is still on track. You will probably have to take off the door panel and check
so i went out and checked it out today, i remove the door panels and everything seems fine. so i decided to bring it to a body shop and have them take a look, they told me that i should weld the door frame and the window frame (the metal parts) because it seems like there is a weld missing. on one side. they use wd-40 lubricant on the weather stripping and it seems to fix the problem, but they say its only temporary.
97Ej8
04-24-2012 04:56 PM
Rattlin_Steele
06-06-2011 10:45 AM
AGibney
12-29-2009 05:59 PM
ic892003
09-12-2007 10:33 PM
