need knowledge about JDM engines
Old 10-05-2011 | 06:45 PM
cska19's Avatar
Default need knowledge about JDM engines
I own a 2000 civic si. Recently the number 2 cylinder has no compression due to a cracked ring. Im looking for a replacement long block. I just need to fix the car nothing performance. I found a long block on a jdm site; it is a b16a 2nd gen. The specs say it is for 92-95 will this block work for my car?
Old 10-05-2011 | 07:06 PM
your car has a cps on the crank since you are obd2b, so unless you wanna buy a obd2b to obd1 jumper and a p28 ecu to convert your civic to obd1 then no , can you make it work... yes but will require you to convert to obd1.
why not just repair your engine?
bp957
09-21-2011 06:05 AM
Guitardude_15
EK Swaps
08-08-2008 04:27 PM
2kSI
11-04-2007 06:49 AM
dee1
07-26-2006 07:24 PM
Quick Reply: need knowledge about JDM engines
