Need HELP PLZ
Need HELP PLZ
I just bought a 92 civic hatch with a D15b8 block, and tonight the dash lights stoped working and then i got pulled over and told my tail lights are not working either. so i check the fuse it was broke so i replaced it but the light still do not work? and the fuse did not brake again so im lost as to what to do next? any help would be great thanks...
Turn the light switch on, test for voltage from each test point on top of the fuse to ground.
No voltage: Light switch is bad.
Voltage on one but not the other: Fuse is blown. If the radio is aftermarket, shorted wires behind the radio are a common problem.
gforce79
03-08-2007 07:02 PM
