need help! only 27mpg in a 92 vx hatch??
Old 01-24-2010 | 07:38 PM
tireking's Avatar
Default need help! only 27mpg in a 92 vx hatch??
so i just got a 92 civic vx hatch. filled it up twice. got 35mpg the first time. then 27mpg the second.. so whats up with that. still has the same motor d15z1. any tips on what to do to get better mpg??
Old 01-24-2010 | 07:43 PM
Your gas mileage will drop in very cold weather. Did you change your driving style or do you drive more city versus highway miles?
Is the CEL on? Does it take an abnormally long time for the engine to get hot?
When were your plugs, wires, cap, and rotor last replaced?
Old 01-24-2010 | 07:44 PM
stuco's Avatar
Did you change driving conditions? City, highway, combined?
Old 01-24-2010 | 07:47 PM
tireking's Avatar
i think i got better in the city. i drove to dallas on the highway. hole shot 75mph. thats when i got 27. i just changed the plugs. and what is CEL? this is my first honda
Old 01-24-2010 | 07:51 PM
supersize's Avatar
Sir Banned-a-lot
cel means check engine light, it will come on your cluster
try going 55 when your on the highway, windows up to reduce drag, and see what ya get
Old 01-24-2010 | 07:52 PM
Driving 75 mph will reduce gas mileage. Try not to exceed 65 mph.
A D15z1 engine should be getting 40 mpg. You should also replace the plug wires, cap, and rotor, and check the ignition timing.
CEL = check engine light
Click here:
http://www.honda-tech.com/showthread.php?t=1901557
Is the engine warming up quickly?
stuco's Avatar
Do a full tune up, your highway mpg will improve if you slow down a little.
Old 01-24-2010 | 08:07 PM
tireking's Avatar
ya it does warm up quickly. full tune up includes what? plugs, wires, cap, rotor, fuel filter, air filter, oil change, anything else to change? what about a new fuel pump. it did die on me today and it took awhile to get her back started
Old 01-24-2010 | 08:12 PM
Yes, but replacing the fuel pump is probably unnecessary.
When you turn the key to ON(II), does the CEL turn on and then off after 2 seconds?
Old 01-24-2010 | 08:17 PM
tireking's Avatar
yes i think it does.
Quick Reply: need help! only 27mpg in a 92 vx hatch??
