Need help! (location of the throttle and iacv?)
Hello.
My car is 1998 HX 2DR Automatic.
I am trying to clean the throttle and iacv to take care of rough idling problem.
Where are they? I spend manymany hoursreading many other posts, but i guess HX has a bit different lay out. It still looks confusing to me. I think throttle is located at the center top in the picture I attached. But where is iacv?
If somebody can tell me where they're located, that will be great!
I have attached a picture of my car inside.
Thank you.
[IMG]local://upfiles/23672/241EFE758686495C8FE03AB34880147F.jpg[/IMG]
Thank you.
RE: Need help! (location of the throttle and iacv?)
Thank you very much to you all you replied. I finally located throttle and IACV, and sprayed some throttle cleaner into it. I'm gonna fire up the engine for a few minutes and reconnect the thing.
However, my idle rpm was usually 1000 - 1500. I read from this forum that the idle rpm should be650 rpm. guess I should adjust "stop screw". right?
Then.. where is the stop screw? .... questions after questions.. :-(
Thanks.
Thanks.
Hey all,
I just finished cleaning the throttle/iacv. All i could do for iacvwas to spray a few shots to the hole between throttle and iacv though.
I used have stall/fluctuate idle problem (when at stop or stop & go moment), but it was fine when I test drove it after cleaning. But still need to drive a few days to be able to actually tell if the problem was taken care of.
Anyway, I really appreciate help from you guys. hopefully this would be the last post regarding to my idle/stall problem.
Have a good weekend!
jlor010
08-08-2010 06:21 AM
jamisonh
02-21-2009 10:17 AM
superfestiva
13
05-26-2006 04:20 PM
