need help with j spec motor swap
here is the deal i have a 95 civic ex i just had a japan spec 1.6 put in and its running ****ty do i need to swap the computers since its a japan spec please someone let me know if this would cause baoging down and speedometer tonot work properly if any one has any help let me know or email me @ sk80914lfe@yahoo.com
RE: need help with j spec motor swap
I think the EX came with a 1.6 liter, VTEC, SOHC engine. If your new engine is the same type you don't need to change the computer.
The speedo doesn't go thru the computer anyway, this is a clue that something else is wrong. Check your ground wires and speed sensor. When the computer doesn't get the proper signal from the speed sensor it will enter "limp home" mode which means the engine won't rev over about 5000 and the VTEC will not kick in.
KenB
09-20-2007 02:34 PM
RamAirTurboPerf
09-27-2006 02:36 AM
dalifts
ED-EF Swaps
04-16-2005 02:11 PM
