Need help getting my 1995 hond civc hatchback running again
#21
Was overheating involved in it stopping in the first place?
One bad cylinder makes these engines very hard to start. You could do a compression test. Also test fuel pressure with a gauge, and/or check for flow out the return line. Use a voltmeter and check that the injectors, distributor, sensors, etc. are actually receiving power as they should.
It would be rare for me or anyone else on the Internet to know exactly the problem with a car, being thousands of miles away from it. In this situation it often works to forget everything you've done so far, and go through the complete "cranks but won't start" rundown again. Assume that nothing is good or has already been checked. Or have someone else look at it.
#22
I don't know if this will help or not, because I'm a bit of novice when it comes to working on cars and totally rely on the help from this forum and thank goodness for youtube. Anyhow, a few months ago I experienced similar problems with my 94 Civic EX. After every thing I read and even did some diagnostic test from a youtube video, it turned out to be my ignition switch harness. I was looking at the main relay and fuel pump, but after doing the test on the ignition switch I knew I had found the problem. Bought one off of E-bay for about 40 dollars and took a day off work to put it in. HTH.
#26
got my firing order correct and that order is for a 4 banger non v tec right ??? tommorrow going to buy a ecu for it found one for 40 bucks off kijiji or 80 off e bay gonna see if thats the prob if not she is going up in flames then scrap yard thank u too everyone for the help espacilly mk378 see your posts everywhere u r a smart person thanks you really helped me along the way to find the prob of this junker but... it has had the better of me and I am done never had this much prob from a honda fuel spark air and tons of compression and won t go it will make a great christmas card photo of it crushed in scarap yard
thanks again to everyone
hondasonic
06-01-2008 07:21 PM
4doorcivic9
10-01-2007 11:44 AM
