Need help ECU gone bad?? Yes or NO
Old 07-16-2005 | 10:23 PM
sacicons's Avatar
Default RE: Need help ECU gone bad?? Yes or NO
ORIGINAL: LEVIII
do you still have fuel pressure?
can you hear the fuel pump fire up when you turn the ignition on? not running, just on?
Old 07-17-2005 | 01:29 AM
nightrider46's Avatar
thanks for all the ads on the fuel pressure and distributor problem but i found out that the module that i put in there was the wrong one . i put the module for a sohc i needed a dohc module.
Thanks for all u guys help
Old 07-17-2005 | 01:32 AM
sacicons's Avatar
you sure? ive interchanged them between a 95 dx and a 00 si.
Old 07-17-2005 | 02:08 AM
what do u mean by that ? my fuel system is fine its just no spark
Old 07-17-2005 | 02:12 AM
I really wasnt listing for the fuel pump firing up but even if the fuel pump was not working i should still see a spark comeing out of the coil to the distributor which means it's probably the module, distributor, the coil or the timing . it has nothing to do with fuel. do u get wut i mean ??
xsteinbachx
08-01-2009 01:09 AM
belias
09-14-2008 02:45 PM
DreamTeam87
09-18-2007 05:04 PM
Quick Reply: Need help ECU gone bad?? Yes or NO
