need air filter help asap!!!
today iwanteed to change the air filter, but the screws holding my air filter cover are tied down hard..... i used penetrating oil and wd-40 on them, i used a phillips head screw driver and i even used a pwoerdrill with a phillips head, still didnt pry even a little bit??? what else can i do, is the last resort taking it off and buying a new airbox?
RE: need air filter help asap!!!
dont the screws also have a 8mm bolt head. if they dont i would try some PB Blaster let it set for a few then try again. Or you can buy a tool that has a phillips on the end and you wack it with a hammer. I cant think of whats its call, but you usethis on rotors to get those little screws out.
yea i believe it does, it has a bolt at theh alf end of the screw, i used penetrating oil and wd-40 and soaked it on the screws, will pb blaster really be more effective?
