Motor swap...help
Old 05-31-2010 | 04:52 PM
Jason D's Avatar
Default Motor swap...help
got a 95 del with D in it and dropped a gsr B in it. I need some help with wiring. A guy started it and had a diagram but he didn't know what he was doing and it is all half a$$ed. dose anyone have a diagram or step by step? i can do it but i at least need a diagram. Plus the motor was rebuilt with better internals and can anyone help with break in proses?
Old 05-31-2010 | 07:21 PM
what wiring diagram do you need, the vtec wiring diagram?
how do you know the motor was just rebuilt? receipts? pictures?
Old 06-01-2010 | 04:46 AM
Jason D's Avatar
Ya im not sure what wire gos where if there is anything i gotta swap over like sensors or anything. ya he has a full receipt but they never got it running cause they didnt know how to wire it up and they said what they did do is a coble job. no i dont have any pics of it yet. but its a 93 del with a obd1 b16 with a hydrolic b18 tranny and the car is hydrolic and they have a p27 ecu
Old 06-01-2010 | 05:07 PM
Jason D's Avatar
No help
Old 06-01-2010 | 08:46 PM
Old 06-05-2010 | 08:20 PM
Jason D's Avatar
ok so i started working on it and i ran into the same problem as most ppl, what plug gos where? anyone point me in the right direction
Old 06-06-2010 | 06:24 PM
SupaviIIin's Avatar
i used google.. i typed in p28 ecu pin diagram. from there, i found out what wire was for what.
Old 06-08-2010 | 05:42 AM
Jason D's Avatar
Thanks that helped alot. i just didnt know what plug went to what. like the MAP and all that, so i believe im on the right track now. again thank you
Old 06-10-2010 | 01:31 PM
Jason D's Avatar
ok i got the motor running when i got the firing order right lol. but its spitting oil out the back and i was told it was an oil line. dose anyone have a site or diagram of the oil and coolent lines are ran so i know they right?
Old 06-11-2010 | 04:59 AM
I don't think there are any external oil lines. Could be leaking from the VTEC solenoid, oil pressure switch, or the oil filter.
Quick Reply: Motor swap...help
