Motor mounts
Motor mounts
My motor mounts have been bad for a while. When i rev it the whole damn thing moves. and im thinking thats why my car takes off like a turtle. So should i get stock mounts cause im on a low budget or are there better mounts for a low price.
Also how do you replace motor mounts? Is it a smart idea to have a shop do it becuase remember. low budget.
Thanks
Thanks
1- it takes off like a turtle b/c it has little to no power.
2- make sure the stock mounts are even bad, stock mounts have a lot of give for comfort.
3- you will need to support the whole vehicle with jacks and support the motor with a block making sure nothing will move, then remove the mounts.
i mean it takes off so slow it wont even chirp them but once it gets past like 15 or 20 it goes pretty good. i can keep up with my freinds Ford taurus SHO V8. its almost like it stalls for a split second then takes off
Edit: i know the mounts are bad. they just look all cut up and nasty
ill look into some stock ones tomorrow.
if its not the motor mounts then why does my car take off so damn slow. i mean i know it only has 120hp MAX and its an AUTOMATIC but its abnormally slow. i drove this one girls car that was exacly the same as mine. D16y7. same everything just this one was stock and it was way way faster
really? i was looking on the internet and it said somewhere around 110. but i got a new air filter and did an oil change and my car seems to be running alot better. ill still get motor mounts soon becuase i got a job interview today so hopefully i get it and i get mounts asap.
Quoted from Wikipedia
"D16Y7 * Found in:
o 1996-2000 Honda Civic DX/VP/LX/CX
o 1996-97 Honda del Sol S
+ Displacement : 1,593 cc (97.2 cu in)
+ Bore and Stroke : 75 mm × 90 mm (3.0 in × 3.5 in)
+ Compression : 9.4:1
+ Power : 106 hp (79.0 kW, 107 ps) @ 6400 rpm
+ Torque : 103 ft·lbf (14.3 kg/m, 140 Nm) @ 4,600 rpm
+ Redline : 6800 rpm
+ Rev-limiter: 7200 rpm
+ Valvetrain : SOHC (4 valves per cylinder)"
Yea, you may have 110, but only 90 or so is making it to the wheels. A new air filter and all that tune up stuff with only restore lost HP from having a dirty filter, or bad spark plugs etc etc. If you can keep up with a v8, 235 hp and 230 ft·lb torque with your automatic, there's gotta be something wrong with the Ford driver....
"D16Y7 * Found in:
