Missing Secondary O2 Sensor Wiring
Old 08-01-2006 | 08:16 PM
csned1's Avatar
Default Missing Secondary O2 Sensor Wiring
2000 Civic LX
CEL on when I bought the car (Code P0141 - Bank 1 Sensor 2). Long story short, I got under the car and found the secondary O2 sensor with four wires coming out of it but nowhere to connect them to.
Does anybody know where I should be looking for the wiring/connector?
I did notice a hole that goes up through the floorboard so I tore appart the center console and looked everywhere up under the dash but couldn't find anything. I have a Haynes manual but it wasn't any help.
Bottom line, I need the car to pass smog. I would appreciate any insight or suggestings.
Thanks!
Old 08-01-2006 | 11:54 PM
98EX's Avatar
Default RE: Missing Secondary O2 Sensor Wiring
The wires come from under the dash on the floorboard on the passenger side.
Old 08-02-2006 | 12:19 PM
csned1's Avatar
Thanks - at least I'm looking in the right area.
Would the O2 simulator I've been reading about work without the old wiring harness? Could it be spliced into wires near the ECU?
[i]Surfing around on this site, I found that this car has had an engine & ECU swap. It looks like the engine & ECU are from a 96-2000 EX (engine=D16Y8 & ECU=P2P). It still does not explain why the wiring for the secondary O2 sensor is missing.[/i]
Old 08-02-2006 | 04:35 PM
csned1's Avatar
Bump
faifu27
06-17-2010 04:25 PM
JW93EX
06-18-2008 08:41 AM
Shingpumps
01-15-2008 01:18 PM
stylincompact
11-12-2007 05:30 AM
FlipHKD720
07-29-2006 10:19 AM
Quick Reply: Missing Secondary O2 Sensor Wiring
