might be helpful for those with TBI
If your having problems with idiling up and down, your engine seems to flood, or you simply can't start it and you have all the components for an engine to run such (spark, fuel, and correct timing) you may want to replace the o-rings on your injectors. You could be sucking fuel past your injectors causing your engine to flood and it will not start!
Lambo Civic
02-23-2008 07:17 PM
