massove electronic failure
a 1988 honda civic dx had its battery grounded while driving and it smoked the dash unit and main fuse relay only check engine light with new dash from an si also when cranking cuz it does crank the bright light and turn singals go on. it has spark . replaces the main fuse relay with another one i had. still the car will not start and the lights will not go on.
RE: massove electronic failure
ok i was driving my car and all of a sudden it back fired i look down and my dash was smoking the car stalled and i pulled over. i open the hood see that the battery grounded. then i hear a clicking and notice its the main fuse realy doing it so i replace that and nothign happens. then i put in the 90 si dash cluster that i had and the check engine light coem on adn so does the blinkers and bright light thign comneon in the dash. the car will crank its gettign gas, and gettign spark whats my problem
xyz357
09-07-2006 08:35 AM
nemesis08
11-13-2005 05:25 AM
