low rpm idel? help
low rpm idel? help
so i was out today trying to relocate my iat sensor into my intake today and being stupid took out the tps sensor and put it in my intake. i then stated my car and in idel with about 100-200 rpm very low, so i put in back and reset the ecu and it still has the smame problum????
What year Civic?
The TPS is located on the throttle body. TPS fasteners generally must be drilled out to remove the sensor. Are you sure you removed the TPS? If so, the TPS must be calibrated when installed (0.5V close throttle, 4.5V wide open throttle). Can you post pictures?
did the bleeding, some air came out but it still didnt do it, could it of been when i took the map sensor out and put it in my intake stupidly, when i turned my car on i noticed the tb sucking in air where the map sensor was and then put it back????? my exahast has been acting wired too putting out some fumes it dosent normally put out and shakes more
sebdiz
04-28-2010 05:45 PM
boostphreak
08-27-2008 11:15 AM
SirTealingstonThe2ND
11-04-2007 06:38 PM
