low idle at stops? hot weather? o2 sensor?
i posted a post on here a few days ago about a CEL i got code # p0131. front o2 sensor.
the same time that light came on, my car would idle really low at stoplights and would actually stall a few times. the weather was hot and humid that day.
i pulled the fuse from the fuse box under the hood and the light went off and the idle seemed fine for the last couple days and the weather was cooler.
today, the light is still off which is good, but the weather is hot and the car started idleing low again and stalled.
even since the CEL hasnt come back on, could the o2 sensor still be bad and could a bad o2 sensor cause a low idle at stops?
2000 ex with 87,400 miles.
thanks
jr
thanks
jr
RE: low idle at stops? hot weather? o2 sensor?
I am looking for a diagram that tells you how to set the idle on your Civic, but I don't find a diagram for a 2000 D16Y5 with a MT. Is the engine possibly a D16Y7 or D16Y8?
