low idle/running rich/flashing CEL but idles fine?
Old 02-01-2012, 06:30 AM
Having the spark suddenly quit when hot, then not be able to start again until cooled off, is a typical ICM failure. It could also be a distributor sensor-- those will usually set codes in the ECU but the ICM will not. Very rarely, the ECU itself, since you've already replace the whole distributor (new parts aren't necessarily good though). A non-working ECU might not cycle the CEL on and back off like it should when you turn the key on but don't crank.
fongcom
02-09-2011 03:02 AM
Try.Fail.Repeat
10-07-2008 06:32 PM
rcherr642z
08-21-2008 01:20 PM
scottdh20
11-24-2007 07:50 PM
Liebers19
12
10-03-2006 12:24 AM
Quick Reply: low idle/running rich/flashing CEL but idles fine?
