Low compression 97 1.6
I know its on the #1 cylinderand its not the valves.
What do i need to fix? is there a kit?are any special tools needed to do the job?
I was told it can be done with the engine in the car but i need to swith out the tranny anyways soill just pull them both out.
the car has 150k on it, Any tips on what should be replaced while i have the engine and trans pulled?
RE: Low compression 97 1.6
When oil is added tothe cylindercompression is good.
mysighnature is not working?
http://cia-gamers.com/members/car.JPG
Here's where to start:
http://hondatech.info/downloads/Auto/Manuals/Civic/
Is replacing the engine an option that you have considered?
I would rather fix this engine, I have already put in a new water pump and timeing belt.
And other then cylinder 1 it'sa good engine.
If itis cheaper to get a used enginethen maybe, but at a junk yard you dont know what your getting.
I have a Haynes Repair Manual its for..
civic 96-2000
cr-v 97-01
integra 94-2000
Iliketo get some help andtipsfrom the forums b4 the job, I plan to do this next weekend.
A manualcan't help with on hand question
civic 96-2000
cr-v 97-01
integra 94-2000
rcgtsport
07-12-2011 04:51 PM
larsenracing
03-03-2006 07:18 PM
nachoman
05-23-2005 02:37 PM
