loud squeak/squeal
loud squeak/squeal
I was driving on the highway last night and when i would let off the gas pedal i could hear a lound type a squeak squeal that would continue until i pressed the gas again or i got slow enough. I thought it might be a belt but usually a belt gets louder when u accelerate, not when u let off the gas. Any help on this would be great!
RE: loud squeak/squeal
one check your belts see if any are really loose. then if its not that its going to be sumthin more of a pain in the ***. a.c. compressor could be going out, same with the alternator, or one of ur pulleys could be failing.
a squeal shouldn't be anything else other than those things i just said. how old is your car? whens last time you had alternator replaced or a.c. work done?
wow, well can u pop ur hood and rev the motor and make it squeal? or is it only happening when driving? i dont wanna make u or me sound dum but ur brakes? cuz there really isnt anything else that would squeal or make like a whistling noise like that
ima say it isnt a belt because like you said it would happen when u start your car for the most part. it has to be a pulley going out. and to find it is tuff especially when its only happening when ur moving down the road.
Scott95
11-13-2008 11:36 PM
ac, accelerator, alternator, civic, compressor, gas, honda, letting, loud, pedal, sound, squeak, squeaking, squeaky, squealing
