Loss of power
Old 12-18-2007 | 09:22 PM
typet's Avatar
Default Loss of power
I have a 95 dx with 180000 it is slow uphill and seems to get going at high rpm?
Any answers
Old 12-18-2007 | 09:33 PM
Default RE: Loss of power
You might be having problems with the fuel pump, filter, or injectors. Alternatively, your catalytic converter is clogged.
Old 12-18-2007 | 09:52 PM
typet's Avatar
Runs good on highway but not up hills.
New pipes on the car. Have not checked much on it yet.
But i guess a tuneup wont hurt. Any idea what fuel pressure schould be?
Old 12-18-2007 | 10:04 PM
ORIGINAL: typet
Here you go:
Old 12-19-2007 | 06:04 AM
Fuel fiilter first of course. If it runs unevenly like it's misfiring, could also be an ignition problem, change the plugs wires cap and rotor. Don't use aftermarket wires. If it runs smooth but slow, consider the air filter or the cat.
Also you can check the fuel flow (pump and filter performance) as follows: loosen the gas cap, disconnect the return hose at the firewall and direct the end from the regulator into a container. Turn the key on (do not start) and you should have a decent stream. If it just dribbles that's not good.
k2rad
16
08-25-2005 02:27 PM
chones2083
05-19-2005 10:21 AM
rzimmer11
03-16-2005 12:32 AM
islandguy
10-23-2004 02:20 PM
jjgarcia
08-02-2004 11:26 AM
