Losing oil, any info will help
Old 03-20-2008 | 08:19 AM
SoCaL.rider's Avatar
Default Losing oil, any info will help
Ok, When I get close to the 3,000 mile mark and I take it in for an oil change I'm always close to bone dry.
1. I'm not smoking out the back
2. no leaks underneath
3. no leaks from the valve cover
Engine looks clean, I dont get it. Where and how can I be losing oil?
I was running 5w30 synthetic, and switched to a thicker 5w50 synthetic. Anybody know whats going on?
Old 03-20-2008 | 09:03 AM
Default RE: Losing oil, any info will help
It's most likely being burned, but slowly enough that there isn't noticeable smoke. Up to 1 quart per 1000 miles is considered "normal" by car manufacturers. Some cars need to be topped up between oil changes. Don't let it run low.
Old 03-20-2008 | 11:26 AM
Alright then, if its considered normal.
Old 03-20-2008 | 12:35 PM
PREKGSR's Avatar
my old gsr was burning a lot and to this day i never new what was going on , now with the new gsr it doesnt burn any oil at all
Old 03-20-2008 | 01:13 PM
FlipHKD720's Avatar
i'm in the same sitch, do you have any oil on your oil pan? That might mean a bad drain plug/gasket or a bad oil pan gasket. Also i got switched to 10w30 i think because it's a bit thicker and won't leak as much? Idk, thats what i've been told though.
Old 03-21-2008 | 06:47 AM
In my opinion, the amount of oil loss you describe sounds a bit excessive. I would recommend that you continue to search for a possible oil leak and to check your oil level more frequently to avoid major engine damage.
Old 03-26-2008 | 12:06 PM
Firehawk989's Avatar
Also depends on the type of driving you do. If you are always flooring it and revving really high, you will burn some oil. Also, if you're going on long road trips over mountain passes in really hot weather, etc. that can burn some.
Under normal driving, I can easily go 3000 miles without burning a drop, but when I go back to visit my parents, (a 3.5-4 hour drive over 2 mountain passes) sometimes I have to add some. I've never seen it get near the empty mark though, so you might have some kind of problem. How many miles are on your car?
Old 03-26-2008 | 03:53 PM
Hailchristian's Avatar
maybe you can check your PCV valve...its a 3 dollar part and if yours is going bad it could be sucking oil into your intake.
sik92civic
02-27-2011 01:09 PM
oilltd
06-10-2008 04:06 PM
kma
15
12-06-2007 06:55 AM
OldSiMan
04-22-2007 12:49 PM
Quick Reply: Losing oil, any info will help
