LOCKUP CONTROL SOLENOID VALVE Code in a standard car
Old 10-11-2008 | 09:26 AM
Tealingston's Avatar
Default LOCKUP CONTROL SOLENOID VALVE Code in a standard car
Hey guys, I just put a new PG7 ecu into my 91 SOHC ZC civic, (used to be a 1.5L), works good got a little power out of it, anyways, its running me a code 19 which is the lockup control solenoid valve and in the book it says (automatic trans axle) so why is it blinking that.. the ecu came from a standard car.. apparently. How do I get rid of this code I hate seeing the engine light. Somebody told me cause the engine lights on you loose gas mileage and power...
Old 10-11-2008 | 11:30 AM
It seems that the new ECU may actually be from an automatic.
Old 10-11-2008 | 04:10 PM
... Is there anything I can do about it?
Old 10-11-2008 | 04:13 PM
Verify that the ECU is for an automatic transmission. If so, purchase the proper ECU.
Old 10-11-2008 | 04:20 PM
How would you actually verify that?
Old 10-11-2008 | 04:21 PM
Not sure. Does the unit have any serial number or other information printed on it?
Old 10-11-2008 | 04:26 PM
Yeah
37820-PG7-A020 then under that 682-111382 then in bold 8W
Old 10-11-2008 | 04:37 PM
Yeah
The link below suggests your ECU is for a 1988-1989 acura integra with a manual transmission, so it's unclear why its throwing an AT code. Does this ECU match with your engine and wire harnesses?
http://www.autoecms.com/parts/Result...ld=part_number
Old 10-11-2008 | 04:42 PM
I have a SOHC ZC and I was told the PG7 gives a better fuel map for these engine rather than the stock Si one, everything else works mint other than that code, at the wiring fit right in, the ecu case itself wouldn't bolt in so I swapped out the insides of each and it fit.
Old 10-11-2008 | 04:52 PM
Wait nvm, the code I gave you was the one that was in the add picture, I just ventured out in the night and got the real one off the ecu itself and its 37820 PG7 A130 and its an auto ecu! Refund.
