location of engine block coolant drain bolt???
Coolant drain plug
PCV valve plate is leaking coolant from behind it is the drain plug located behind the PCV valve plate on the back of the motor 2001 Honda Civic ex
if not how could coolant get inside behind the PCV valve plate is anything behind that plate
rbnz
06-07-2016 11:00 PM
slowstepper
12-20-2014 05:37 PM
ELLAS1945
07-12-2007 12:13 PM
