Lights dimming, wipers slow
Need some help -
Engine is warmed up and when I stop for a light or what ever reason -
The interior lights dim, wipers slow or stop, and rev go down a bit.
I'm thinking alternator is the problem but how and what can I check to be sure.
sounds lika a alternator. is that all its doing? is the raido going off and on any other problems. or it could be a dead battery.
Does the battery/charge light ever illuminate when the car is running?
Sounds like an alternator problem; however, start with the basics first.
First, thoroughly clean the battery posts, connectors, and ground wire. Next measure the voltage across the battery posts with the warm engine idling. Compare that voltage to what you get when the high beams are ON and blower is turned to MAX. What values do you get?
Did you need to rev the engine to maintain that high voltage. If not, did your light dim as mentioned in your thread title? If not, when does this problem occur?
I'm starting to think you may have a low idle problem. Have you cleaned the IACV? Is your ignition timing set to spec? Are your plugs, wires, cap, and rotor fine?
