leaky block?
ok before reading this.. you can call me dumb.. i think its just the engine oil cooler doing its job... just because theres no other pressure or filter to plug the hole its causing it to leak thru.. i could be horribly wrong though
so someone correct me.. and call me dumb if you must..
i turned the car over.. luckily i didnt have an oil filter on.. but its pissing coolant from the oil filter fitting... any ideas?? i thought i had broke a line and was gonna be pissed cause its nearly impossible to reach up under the supercharger where all the lines are but then i had my wife come out and its pushing it right out the lower parts of the basin.. not the shaft itself .. at least i dont think...
yes... but the coolant lines are soo simple because i didnt change any lengths and they are all headed in the places they should be cause i double checked that... the only thing i could think would be theres an o ring or maybe the oil cooler sandwhich might be shot itself
curlybandit
11-16-2005 01:42 PM
garyshed
07-02-2005 09:37 AM
