Knocking in 99' Civic Cant figure it out.
Old 07-11-2007 | 11:09 AM
GJ6167's Avatar
Default Knocking in 99' Civic Cant figure it out.
Hello. Hopefully I can get some help here. About two weeks ago whenever I make a left turn, there is a "knocking" coming from what seems to be the back right side (wheel area?) of the car.It stops as soon as I complete the turn. I had it over to a local place to look at and they said they checked the emergency break cable which needed adjustment. It seem to stop, but started up again later that day. Its only when I make a left turn. Any ideas what may be causing this? Thanks for your help.
Old 07-11-2007 | 12:24 PM
gwl's Avatar
gwl
Default RE: Knocking in 99' Civic Cant figure it out.
It can be a bad wheelbearing.
Old 07-11-2007 | 01:17 PM
Jack up that wheel (don't remove the wheel, just lift it off the ground) and see if you can wobble it from side to side.
It is also often helpful to have someone standing outside and drive past them so they can listen and try to better locate where the sound is coming from.
Old 07-11-2007 | 03:36 PM
GJ6167's Avatar
ORIGINAL: mk378
Ok, jacked up the wheel and it doesnt wobble at all. I checked to see if anything with the exaust is loose and bouncing. Nothing.
Old 07-13-2007 | 10:36 AM
GJ6167's Avatar
Well I broke down and took it to Honda. They said it was the rear breaks. The break shoes needed to be replaced and the drums needed to be resurfaced. So no more noise. I never would have thought it was the breaks due to the fact that I was never breaking when it made the noise. But what do I know. [&:]
Kilroy
06-11-2015 05:26 PM
keigaro
05-21-2012 09:53 AM
edyo74
09-24-2006 10:37 AM
tonguetwiztid
07-19-2006 10:13 PM
solewheelin
07-07-2006 07:18 AM
Quick Reply: Knocking in 99' Civic Cant figure it out.
