knock sensor and high nox
hey all i have a 94 dx with a b16a in it, i get a cel 23, the knock sensor. it seems like the lights will only go on at higher rpms, i reset the ecu so i could try to pass echeck, i failed because of high nox readings. if i replace the knock sensor will that help my readings?
Probably not.
What were the other pollutants reading? Failing on NOx but with unusually low HC and CO means it's running lean. If all 3 numbers are high, the cat converter probably needs to be replaced. Also if equipped (California version), the EGR system may not be working.
Acceptable, yes, but how do they compare to normal / average? If you run lean, the CO and HC will go to near zero, which seems great, but it'll fail NOx. So the other readings can be a useful clue for why NOx was too high.
milrite007
01-15-2011 08:25 PM
Specialbrownie
05-02-2010 07:38 PM
