Kill Switches
Kill Switches
Hi,
Well my first safety measure is a fuel pump kill switch. Im just wondering where I can access the fuel pump wire on a 98 honda civic EX. I am following this guide: http://www.courtlukens.com/Tech/cutoff_switch.htm and im just wondering if its the same spot or not.
Thanks
Jeff
Thanks
Jeff
RE: Kill Switches
I'm working on a similar project for my car now. I'm gonna disable the fuel pump and the starter at the same time.
Check this out.
https://www.hondacivicforum.com/m_48447/tm.htm
Check this out.
RE: Kill Switches
ORIGINAL: ngoti8tor
Check this out.
Check this out.
Hey,
I read that on a quick search I did. Looks complicated althought Im sure its not I have no idea when it comes to electrical stuff so I am trying to keep it simple with just a switch. I woulden't mind another switch for the starter but thats another project after I complete this one. I even thought of running 2 fuel pump kill switchs, 1 inside the car and 1 in the trunk. I would only ever use the trunk one of I was away from the car for along time. Just a thought.
Jeff
RE: Kill Switches
ORIGINAL: Mad7s
Why not just get an alarm with a kill switch?
ORIGINAL: Xoopiter
You hook it up to interrupt your fuel pump circuit and your starter circuit. May sound complicated, but it's not.
If you need any help Xoopiter, just PM me.
RE: Kill Switches
ORIGINAL: Mad7s
How?
How?
