key wont turn in ignition
Old 08-01-2007 | 08:34 PM
Jgraham87's Avatar
Default key wont turn in ignition
I have a 96 Honda Civic Ex Coupe, and today it started doing something weird. When I went to crank up my car the key would not turn. I could put the key in, but then it wouldnt move, I kept taking out the key and trying to start the car again, but the key was stuck in place it would not move. Finally after about ten minutes I got the car to start up. Can someone help? I have no idea why it is doing this, today was the first time this happened.. Also once the car was running if I took the key out, I would have to fight with it again for about ten minutes to get it to star.
Old 08-01-2007 | 08:42 PM
b8teen's Avatar
Default RE: key wont turn in ignition
there is a plastic switch behibd the lock cylinder, thos have a tendency to wear out. u can pull it out and check it for wear.. amd you can find it by looking at the fuse panel underneath the stearing wheel. there is a square plug plugged into the fuse box. follow that to the switch.
Old 08-02-2007 | 06:36 AM
jeff948594's Avatar
is the key warn down?
Old 08-02-2007 | 06:40 AM
My04Civic's Avatar
Administrator
was the car all the way in park? if its not all the way in gear, the key wont turn
Old 08-02-2007 | 06:46 AM
mxs's Avatar
mxs
did you try turning the steering wheel?
Old 08-02-2007 | 06:55 AM
My04Civic's Avatar
Administrator
ORIGINAL: mxs
yeah, that too
Old 08-02-2007 | 07:26 AM
Jgraham87's Avatar
yeah, the car was all the way in park, and i did try turning the stering wheel, and the key isn't worn down, I check all those things and still nothing.
bwdrennan
07-14-2024 04:39 PM
shadowfetus
12-13-2012 09:46 PM
WellFedHobo
09-19-2012 07:24 PM
vinodpatel52
04-06-2010 06:40 AM
Phantom549
16
01-21-2009 02:07 PM
