JunkYard2
RE: JunkYard2
you have one right? i dont think you should unless you want one just "in case" or you want to build it. If you think cuz you have a non vtec bottom end with a vtec head... and would be better off with both. I heard that the d15 bottom end is a little better than the z6. However, with the y8 head gasket it makes the C:P a little better. If i were you, id stick with the mini me.
