Intermittent idle issue
Hello gang. Civic 2001.
I have an intermittent problem. I will not have it for a day or two, then I will. Sometimes it happens in the morning, sometimes at night. It always seems to be after the car has been turned off for a little while. Once the vehicle warms up, it is usually fine for the trip.
This only happens at very low RPMs. When I am driving at 30+ mph I am fine.
Start the car, put it in drive. When you give it gas, the idle drops and the engine struggles and wants to stall. You give the gas a few quick punches and finally the gas seems to make it to the engine, and when it does, there is now too much gas and the engine revs and you are off.
My initial guess is that the fuel pump is starting to go. When the car starts it struggles to work properly, but when it warms up it is okay. Eventually, I would expect the unit to just cease.
I have ordered a new pump unit and will have it tomorrow. Does this make sense as a diagnosis? I am at the time when the pump should probably be replaced so I consider it a reasonable investment. Could it be something else? My check engine light is not on.
Sounds like a sticky IACV to me. If the fuel pump were that bad, the engine would totally starve for gas when you try to drive it. Basically it would be impossible to go anywhere. When the car drives OK but won't idle, suspect the IACV first.
Read the posts in your thread. You don't have an idle problem, so cleaning the IACV is unnecessary. Replace the spark plugs if they are old and, if the problem continues, measure the fuel pressure.
mudhenFUF
01-16-2023 08:43 PM
90lx
01-22-2013 10:47 AM
MBrent
09-11-2009 01:35 PM
Brian
03-01-2008 05:18 PM
paintman17
09-19-2006 09:14 PM
